Darius wrote:So what you are saying is that the controls work properly when the engine is heating up, but if you turn the car off and let it sit for an hour, the fans would still be running?
yes. it has actually done that for longer than an hour, and even when the engine temp has gone way down. took it to a local meet the day i first installed the controller and the fan was going the whole time in high, engine off.
is that normal for the temp sensor to stay at the same voltage? could my ground be bad for the temp sensor? i have a power fc, and thats what i use to monitor my engine temps and it gets the same signal from that same sensor i believe so i dont understand why the voltage would stay the same
