PorkChopExpress wrote:the above picture is the current timing grid im using. coolant temp 80c.never gets above 85c.
if your physically feeling it pull timing out, you need to try a stock ecu and se if it does the same thing. if it does you need to take a look at the car.
if not, load a factory map up into nistune. start your car and let it get to a steady idel (750rpm) turn on your software and check the timning with a light. does your timing match the # in nistune? if not mess with the cam angle sensor until it does.
once it does take it out for a spin see if it still pulls timing. if so i would disable the knock maps (i did on mine)
and take it for another spin.
if its still pulling timing i have a feeling i would want to put it on a dyno and verify its pulling timing while doing a pull through the rpm.
hit up nistune forums too theres alot of stuff that decides the final timing # and u need to check it all
