How does the active suspension "inflate"
qsiguy
Car: 1994 Infiniti Q45 Turbo
I was looking at an old photo of my active model and it wasn't sittin as low as it is now so it obviously "deflated" while sitting. What makes it "inflate"? I charged up the battery and turned on the key, flipped the active switch and nothing happened. Does the engine have to be running (which I can't do as the car sits)? Is there a mechanical pump on the motor for this or is there a relay or something I can manually power up to inflate it? I was wanting to pump it up to make it easier to load on the flatbed truck for transport.
qship96
Car: 1996 Infiniti Q45
System runs off engine driven pump, motor must be running to move the fluids into bladders
qsiguy
Hmm, thanks. Wonder how difficult it would be to spin it manually with a drill or something.
qship96
If I recall correctly, it takes 5-9 horsepower to operate the pump
qsiguy
Well the idler pulley was off for that belt so I put my air ratchet on the pump and spun it for a while at a time, letting the air compressor fill up for a bit every so often. Took a few rounds with the ratchet but the car is about 5/8" higher now. Should help a little getting it on the tow truck. I'm not sure how much higher it would go. If you jacked up the car to take the pressure off the shocks I think it would fill up faster/easier.
