How does the 5 speed handle after the swap?
BOOMSHAKALAKA
Would like some feedback...thanks
sci2000tech
Car: '92 Nissan 240SX S13.5 RB20DET 'Vert
I have an RB20 5 speed in my vert and I havn't had any problems with the transmission/shifting.
Doesn't affect handling.
Trans is lighter, but not THAT much lighter.
whiteonwhite240sx
Car: 96 240sx
only 100 lbs which is = to 1 tenth of a sec. off a 1/4 mile run!+imeadeat throtel possition+a lightend flywheel makes a BIG diffrance! o yah its alot more fun+eazer 2 drift! im sure theres more power 2 the ground so unless u like auto ,manuel out waighs in many aspeckts!
Hijacker
Car: '92 240sx Convertible
'94 F-150
umm....slushbox versus 5 speed? all i can say is i wouldn't want to shoot myself. I drove a vert before we swapped the motor with a stock KA and slusher. I HATED it. glad I never had to drive my car with that pairing
BMAR240SX
Car: 1993 Nissan 240S Coupe
Its pretty cool driving becomes more fun i see it with more handling becuase your in control of the shifts...
BOOMSHAKALAKA
wow this thread got woken up from the dead...
haha i remember this thread...when I was new guy around here
slownslurious
handling is greatly improved because transmission doesn't try and shift in the middle of a curve. other than that.. nada.
Acecool
Car: 1989 Nissan 240SX Hatch Pig KA24E 126k
About a 300 KG difference, so 600+ pounds should be shaved (off newer cars)
slownslurious
5 speed swap will NOT drop the weight off the car 600 lbs. off any 240.not sure where you got that from. 5 speed swap alone will be lighter because the tranmissions itself is significantly lighter, but you are also adding the flywheel, clutch pedal, clutch master cyliner, line, and the fluid.I'd guess total weight different between the swaps to be 125 lbs or so at the most. Probably closer to 100.
