Nav 4X4 »
https://forums.nicoclub.com/nav-4x4-u72162.html
Wed Aug 01, 2007 1:11 am
Thanks heaps for the info guys, its really helpful.
Just another question if I may, under neath the cam chain cover, apparently there are two o ring type seals, to the left of the crank, near where the oil pump goes,(these are only visible when the cover is off ) anyway I didnt get these with my kit,..should I get some from nissan and replace or can I just leave them where they are and assume they are ok?
also with my sump, Im not sure what to do, I dont know whether to take the whole thing off ! ( big job ) or just undo the front half of the bolts to lessen the preasure on the timing cover, and just try and cut the gasket around the front and slide the cover out, if I do that, can I successfully resilicone the front part of the sump to get a good seal, is it worth the risk? Or should I just undo the two front sump bolts, and try not to disturb my sump gasket at all.... cause I have to look after the head gasket as well when I put the cover back on !! ( hmmm, hard !! )
What have you peoples done before that works ?? Cheers.
