Q45tech »
https://forums.nicoclub.com/q45tech-u112.html
Wed May 20, 2009 6:13 am
IAC duty cycle [10-15%] plus +- in ignition advance to hold a preprogrammed rpm. Ecu increases IAC in steps at some point it tries a 1 or 2 change in advance. The goal is to try to maintain rpm without exceeding say 50% IAC duty cycle.
5 grams per second of air needs 5/14.7 or 340 milligrams of fuei per second. 660 rpm = 1.1 revs per second so 2,3, or 4 [I4, V6, V8] fuel squirts per rev.
In most Nissan engines the cylinder volume = 500cc>600cc so every cylinder is within 20% so amount of idle air and fuel is within 20% at exactly the same rev. Add to that whether 2, 3, or 4 gulps per revolution.
Obviously a 2 liter I4 comsumes less air and fuel than a 4.5 liter V8 does at idle ....................1 liter vs 2.25 liters [air] per second, minute, hour is kinda significant.
One thing one must consider is that at idle the engine is restricted [throttle/IAC] to just about 20% volumetric efficiency so the cylinder only fills ~~ 100cc instead of its full volume of 500>600.
Newer 3.7 have greater than 600cc cylinders ~~616cc
