MetallicSlate wrote:The CVT system is a constant variable gear ration, even in manual shift mode. It will always try to find the most fuel efficient (or power efficient ratio) possible, depending on application. If you're in 5th gear at 1200 RPM and you gun it, its not going to move the needle. You need to downshift like any other car.
That is not true. The CVT's manual mode allows you to pick from gear ratios, with artificial shift points created by the computer and transmission.
You do not need to actively downshift when in 5th gear at 1200RPM. By pressing the pedal down (past the click), it will downshift for you. This will happen regardless of the gear you are in, unless downshifting will cause you to redline.
Here's two ways to drive fast:
- Start in manual mode. Gas it! Just before 4,000 RPM in 1st gear, throw the shifter in CVT mode. And off you go! The reason this works, is because you'll get to the upper band faster in 1st gear, than in CVT mode. But timing this can be hard. If you miss it, and you're now past 4,000 RPM, do not throw it in CVT mode because it will upshift for you. Instead, let it redline and upshift automatically. Stay in manual mode into 2nd gear, and try again by switching to CVT mode around 3,900 RPM.
You can do this while at slow highway speed - about 50mph. From CVT mode, switch to manual mode. You'll end up in 5th gear. Downshift to 4th and gas it to 3900RPM. Then before you hit 4000RPM, put it back into CVT mode. If you're going 65 or faster, downshifting to 4th will put you above 4000RPM. If that's the case, switch to manual mode and gas it in 5th to 3900 and then back to CVT mode.
- Throw the car into CVT mode. Hold the brake down until you gain some RPMS. Release the brake. Brake pads are cheaper than a transmission.
