glitched »
https://forums.nicoclub.com/glitched-u17528.html
Thu Jun 18, 2009 3:12 pm
the drive shaft just slides out of the transmission.
for example, if you were removing the transmission, all you would have to do is unbolt the four bolts that hold it to the diff, and undoo the bolts holding the carrier bearing, then the ds would just pull out of hte transmission easily.
