how do you turn up the boost on a stock sr20det
johnnyappleseed
Car: s14 240sx with s13 sr20det
is the only way to turn up boost with a manual boost controller? and do i have to tamper with anything else? cause i trie using my mbc but it wouldnt change anything. could i get pictures of your guys setups?
DuckyD
Car: 1995 240SX
You have the MBC on the vacuum line leading to the turbo?You may have the boost controller on backwards if your adjustments don't change anything.
johnnyappleseed
have it between wastegate and nipple on hot pipe. which maual boost controllers are good
DuckyD
Car: 1995 240SX
They're all the same.
