How do you turn the engine manually?
SlidnSideways
Car: 97 Nissan 240sx SE
Hey all...I need help with just what it says. I think my timing is off and i need to know how to manually turn the engine to see if everything is ok. So how would i go about doing this?
redwolf5514
Car: 89 240sx coupe ka24de swap. soon kadet!
do yu want to start the car or just turn the crank to line up the timing marks?
Structure240sx
get a socket wrenh and a socket (1 1/16"maybe) and put it on the bolt inside the crank pulley and start wrenching.
benemorius
Car: s13, s13, eg, e36
27mm on a KA. Turn it clockwise.
SlidnSideways
Thanx every for your help. Im in the process of tearing my engine apart to replace the timing chain. Mine skipped a couple teeth which was causing my car not to start. Looks like ive got quite alot of wrench turning to do
