how do you tighten all belts on j30
kevin77
Car: 94 infiniti j30t
had new belts put on about a month ago. and now one of them is now sweaking. i dont want to go back to the dealer cause it will take a day.if some one can tell me what to do to tighten them.
Ebbtide
Man, you could be chasing this problem for a while. I would take it back to the dealer and have them fix their problem. Once you touch it it may become your responsibility.
Otherwise, take off the engine cover and you will see belt tensioners. It is fairly self explanatory.
For the alternator loosen the locking bolt and adjust the tensioner. This one has to be very tight.
For the A/C you need to adjust the idler pulley
For the steering, it set up like the alternator I think.
kevin77
thanx. i got them tightened. problem solved.
