Q45tech »
https://forums.nicoclub.com/q45tech-u112.html
Sat Jan 25, 2003 10:26 am
The curve of the voltage increase is not linear!... with air flow in grams per second. A complex exponential equation is used by ecu to translate the voltage into flow. But at max rpm and max flow {grams per second} the reading should be 4-4.4 volts [this 0.4 VDC range represents a more than doubling of the flow at the top.
Very linear at low-medium flow rates [1.0-1.8 VDC] is a HALLMARK of Nissan MAF.
Note: CFM is a variable and inaccurate definition as the mass changes 1% per 11F and the humidity and barometric pressure affect the AMOUNT of oxygen in a cubic foot of air.
CFM at SAE STANDARD temp, pressure, humidity is correctable but grams per second is always grams per second.
