How do you test the cam timing solenoid?
racer59
Car: 2002 Infinity QX4
So I'm getting code P0011. I'm pretty sure the sensor is fine. How can one test the cam timing solenoid?
Thanks in advance.
atraudes
Car: 2001.5 Infiniti QX4 4WD
I'm gathering from your first post that you have a 2002 QX4. It looks like there isn't a way to do it without a CONSULT, though you may be able to with an oscilloscope if you could figure out what to hook up to. The full details on the code can be found in the Engine Control section of the FSM on page EC-162.
I'd recommend updating your profile info to include the year. That way you won't need to include what year your car is every time you post :biggrin:
racer59
Thanks for the help atraudes. When i bought the car a few weeks ago the seller told me he had replaced the solenoid. I thought maybe it was a faulty part. I see on site that many people believe this could be a low oil pressure problem. Any thoughts about doing an engine oil flush? I updated my profile. thanks
