Right when I press the breaks I feel loss of power, takes seconds to get back, sometimes even stall. sounds similar to mine. Hopefully its my IACV . When taking out the IACV do you have to take the intake? Seems hard to just unscrew it from there. I have a sr20det stock intake.vancouverbc wrote:I'm trying to trouble shoot stalling while idling . When I decelerate to a stop, the idle drops very low and sometimes stalls. It usually goes down to around 300/400 rpm and takes about a second to go back up to 700 rpm.(when it doesn't stall).
My idle was a constant 700 until I cleaned throttle and removed aiv so I think the high idle is just a result of previous owner playing with calibration screw on throttle linkage. I have a constand 650-700 rpm now that i adjusted calibration screw.
the iacv is located in slightly difffernt place on sohc but it applies. No, you dont have to seal anything. it is just intake air. very simple to clean.rob808 wrote:can this be applied to the SOHC engine also?im having the same idling/stalling problem as well.also when prior to installing the IAA unit back on do you have to seal again with epoxy?
thanks bc for your quick reply.i did this to my unit and not knowing there was a gasket there i had to wait till parents got home to make a trip to checkers to get some gasket maker.after installing everything back on and starting up,let it warm up,it idled perfectly,but i guess under load it still almost stalled on me.vancouverbc wrote:
How would the strainer have any affect on this situation?WhiteKnight wrote:Check the strainer below the fuel pump...Braking throws gasoline forward in the tank.
