how do you tell if a manual trans is good before install
240driftguy
Car: 91 240 sx
is there a way to tell if a manual transmission is good before i install it? the shifter is removed but if i bolt it to the transmission should I be able to shift through the gears? I just want to be sure its a good manual transmission before I install it. I bought it used for my 91 240
OutToWinPAHC
Car: 2015 Chevy Silverado
Nissan Skyline R33 GTS-t
Nissan Skyline R32 GTR
Nissan RB20 E46 RHD
2015 Harley Vrod Muscle
1990 Nissan Patrol
MAkes sure it does into all gears smoothly, make sure there are no case leaks, and hope the syncros are good.
240driftguy
Car: 91 240 sx
OutToWinPAHC wrote:MAkes sure it does into all gears smoothly, make sure there are no case leaks, and hope the syncros are good.
will it shift the gears still when the trans is out of the car
S13_RB25
Car: A 240 but no RB yet!
Yes it will shift, the only time when it doesn't go into gears by itself is when it requires you to push the clutch. Which, off course, is when the engine is running.
obg3506
Car: 2006 Infiniti G35
1995 240sx SE
I dont think thats a good way to tell! my transmission snicked into every gear like butter out of the car, put it in and under load it grind like sob so...
