How do you tell difference between 26mm and 30mm z32 brakes
Cgeigert
Car: 1989 Nissan 240sx
I have a complete z32 brake set up that I got years ago, but I forgot which size the calipers were. Now I'm going to by the rotors but need to know which size I need. How do you tell the difference between the calipers?
simmode1
Car: Red '95 S14
And to piggie back that, how do you turn 26mm calipers into 30mm calipers?
simmode1
Car: Red '95 S14
Just threw that question out there because it was probably the next question you might logically ask. I too lazy right now to search too hard for it, but I bet the answers are in here:
how-to-ultimate-z32-brake-swap-w-lots-o ... 86360.html
Admins need to fix the pics in there though...
Dittoz7
Car: 1997 2f0WtY SE!
Ruler?
cjmirabal1
Car: Past: 90' S13 fastback
CA18DET powered
Current: 90' S13 fastback
Vh45de powered
Dittoz7 wrote:Ruler?
^^ :lolling:
Razi
Car: Moo
Cgeigert
Thanks for the pic Razi. When i use a measurement caliper like shown above, I get a little over 30mm. So, given the pic above, does an approximate 30mm measurement mean it is a 26mm caliper?
Cgeigert
And a magnet doesn't stick so they are aluminum. Thanks for the thread link sinmode1
Razi
Car: Moo
Cgeigert wrote:Thanks for the pic Razi. When i use a measurement caliper like shown above, I get a little over 30mm. So, given the pic above, does an approximate 30mm measurement mean it is a 26mm caliper?
Yep!
If it's wider than 30mm, it's a 30mm caliper.
Cgeigert
Kinda funny how a 26mm caliper has a measurement of 30mm.
94_240sx
Car: 94_240SX
Cgeigert wrote:Kinda funny how a 26mm caliper has a measurement of 30mm.
Because you need a little bit of space between the rotor and caliper. I think I saw someone put 30mm rotor on 26mm caliper by accident. It fits, but rotor kinda damaged the caliper when rotating and braking was not good at all.
Cgeigert
I now ended up with 3 complete sets of 26mm brakes, so I have one complete set for sale, plus I'll sell a pair of rears too.
simmode1
Car: Red '95 S14
OP, google "Making 26mm Z32's into 30mm Z32s"... You might find that useful.
Apperantly, the only real difference between the 26mm's and the 30mm's is a little washer that you can insert as a spacer. Voila! Instant 30mm's!
