I'd definitely suggest a dash removal tool. You can certainly use a flat head screwdriver but you run the risk of marring pieces.
If you can't find a service manual or other online reference these install instructions for the Panavise bracket for the Rogue might help you out. Installation of the Panavise bracket requires removal of the head unit.
http://www.panavise.com/pdf_indash/751311508.pdf
vivtri2 wrote:And the final question for now is what are some in-dash kits that interest you? I read some topics on the kenwood and alpine but I'm just curious. I already have the Smart Mirror installed with a navigation system and a rearview mirror. I simply want a system that looks good and I can control my ipod straight from the dash. I don't have a bose system so i can use the PXAMG cable.
You might need to better define what you mean by "dash kit". Dash Kit typically means the plastic bezel and brackets that go around the aftermarket head unit to fit it to the dash. Wiring harnesses, iPod intefacing and steering wheel interfacing are typically separate items AFAIK.
For example. here's the Scosche dash kit. It's just this piece in the photo:
http://www.scosche.com/products/productID/1645
Why are you looking into a dash kit if you're not replacing the head unit? If you're getting an aftermarket head unit then get one with an iPod interface and then you won't need something like the PXAMG.
Modified by takeshi at 5:22 AM 3/31/2010
