how do you...
QxMan01
Car: 2001 Infiniti Qx4
disable the power radio antenna? i got a new head unit installed and the antenna comes up everytime the head unit is powered on, rather than only when the radio comes on (like stock). i would prefer to just disable the antenna entirely, since i almost never listen to the radio, how is this done? i opened the hood and concluded that the antenna motor is hidden behind some paneling and i don't know how to access it. also, does anyone know where i can get a rear wind deflector? (the ones that are mounted above the tailgate window). anyone know? thanks!
Sarlacc
Car: 1995 Pathfinder SE 5spd
QxMan01 wrote:disable the power radio antenna? i got a new head unit installed and the antenna comes up everytime the head unit is powered on, rather than only when the radio comes on (like stock). i would prefer to just disable the antenna entirely, since i almost never listen to the radio, how is this done? i opened the hood and concluded that the antenna motor is hidden behind some paneling and i don't know how to access it. also, does anyone know where i can get a rear wind deflector? (the ones that are mounted above the tailgate window). anyone know? thanks!
If you read my post I have been dealing with the whole h/u, new stereo system myself.
Final answer is, I don't believe you can. For whatever reason they designed the antenna connection to send part of the power to the headunit. So, if you disconnect the antenna...it wont turn on. You're kinda stuck with the antenna always just coming up. Unless you just want to bust the motor...
I was hoping to find a newer stationary attenna, like the small ones covered in a black plastic. Looks a lot better, and no motor noises.
pathfinder_se_black
Car: 2000 pathfinder, FG2 civic si
have u tried unpluging the antena from the head unit, try junk yards for the rear wind deflector
Sarlacc
pathfinder_se_black wrote:have u tried unpluging the antena from the head unit, try junk yards for the rear wind deflector
As I mentioned before...doing so will not allow your head unit to power on.
bml94gxe
Car: 03 Pathfinder 3.5
I placed a switch between in the wire to stop it. I am trying to remember what color the wire is.... anyways i can look it up if you want but now my stereo works and i controlo the antenna
bml94gxe
no thats not what triggers the antenna to go up and down....it is a wire, the color is solid blue after market wiring harnesses.
so what i did was go to radio shack and buy the smallest toggle i could. Then cut the wire and installed the toggle in between and hid the toggle. this way i can turn it on and off when i want to.........and everything still works
elwesso
Car: 94 Infiniti Q45t 5 spd
2007 BMW M Coupe
2007 Infiniti G35 S 6MT
you should just be able to unplug the wires from the motor itself, right?
