How Do You Swap Digital for Analog Gauges?
rico05
Car: 1992 RMS13 w/ CA18DET
I am about to give up on my digital gauges, so I think I may jsut go for analog ones instead of paying out the @$$ to get the digital unit fixed. I may as well go for a JDM cluster as well, since I will be doing an SR swap soon. Thanks for any info. BTW, the car is a 91...
quiksilvia
Car: 95 s14 se
u have to get the harness that plugs into the cluster, and go find it on ebay
Dattebayo
Go find what on e-bay? The cluster? You can get that at a junk yard. Its not like they're that rare... i've seen like 1 out of 10 at the one here (but i dont know how thing are out in norcal). Anyway what about the "heads up" display? I wonder if that will work with non digital cars...
quiksilvia
Car: 95 s14 se
hud only came with digi clusters, and he said he wanted the jdm one, which is from japan, which wouldnt be in a us junkyard.
" I may as well go for a JDM cluster as well, since I will be doing an SR swap soon. "
read next time
rico05
Thanks! In fact, there is a JDM cluster w/ harness on eBay right now!
VitaminT
Car: 93 240sx SE
Does anyone know if the pinouts on the JDM harness are different.
I just did a SR swap and thought about using the JDM harness and cluster or JDM harness with US cluster.
BTW...I am running a digidash and hud in 93 SE (which I don't think came with the digital optio) and it works fine.
quiksilvia
Car: 95 s14 se
it should be the same
VitaminT
Car: 93 240sx SE
Cool. I just didn't know with all the SR pin outs being changed up in the interior harness is it would be the same of the cluster harness.
quiksilvia
Car: 95 s14 se
huh?
VitaminT
Car: 93 240sx SE
Nevermind it's cool. I was talking about how the engine harness had to be spliced inside the car, but it dosen't matter. Thanks for the info.
book-ends
Car: ???? Nissan 240SX coupe S13
I was under the impression that a JDM cluster wouldn't work with the KA because the tach signal is different. If I'm right, what's the point of getting a JDM gauge cluster if you don't have the SR motor?
drifts14x
Car: Cars, Motorcycles, Drifting
Hey guys, out of curiosity, is it the same to use a junkyard US cluster, meaning, do I need to get a new harness to use a US cluster instead of my digital w/hud? (sorry to barge in on your post rico05)
VitaminT
Car: 93 240sx SE
The harness is different for the digi cluster/hud and the analog cluster. You will need to get the harness to swap clusters from digi to analog.
quiksilvia
Car: 95 s14 se
jeansguy wrote:I was under the impression that a JDM cluster wouldn't work with the KA because the tach signal is different. If I'm right, what's the point of getting a JDM gauge cluster if you don't have the SR motor?
he said he is getting the sr, but in 89/90 240's u need the jdm cluster
turboex
I have both a 92 digi cluster (usdm) and a92 analog cluster (usdm) in front of me right now and they use totally diffrent plugs on the rear. The digi uses 2 big, 1 small, and one for hud that does not need to bee hooked up to operate. The analog has 3 or 4 small plugs. Hey whats wrong ith your digi setup? what broken?
quiksilvia
Car: 95 s14 se
thats why i said you need the harness, they ultimately plug into the same thing
rico05
Well crap. So basically, I need to buy a USDM cluster and harness, then get a JDM cluster w/ harness when I get my SR here in like 5 months? Darn....This sucks hardcore...
Ok, does the HUD and digi gauges work on an SR?
turboex
It does not matter what motor is in the car, Just cause you swap the motor does not change anything about the gauge cluster.
rico05
Well, I had a friend that is really into S13s and long before I was, and he said that one had to switch to JDM gauges when doing a SR swap. SOrry for being a moron...
quiksilvia
Car: 95 s14 se
if you have an 89/90 car, and keep the sr speed sensor, the speedo and tach will not work, if u have a 91-94, the cluster will work, if he gets the jdm one now, it will work fine, he has a 91, and doesnt want to pay to get th digi fixed, now drop it
rico05
quiksilvia...you are my new online hero. Thanls for ALL the help! Really makes my life easier:)
quiksilvia
Car: 95 s14 se
score for me
VitaminT
Car: 93 240sx SE
Here are some pics of the clusters and wire harnesses.
rico05
I can see the similar ends to the harness. Looks like a direct clip in affair. Thanks for posting that VitaminT!
240_Keyy
Car: '90 240 Fastback
hey rick, the black 240 in the junkyard here still has the analog cluster, so you should be able to gank the harness out of it...
it is at HWY 6 auto salvage, the cluster is fuxored, but the harness should still be good
rico05
Keith, you own. Thanks man....
