how do you retard or reset the timing on the 240sx OHC?
exodus5547097
rogoman
Car: 1991 240SX FB
2012 Altima 2.5 S
Here's a procedure for setting up the distributor timing:Fully warm up the engine. Shut engine off. Disconnect the TPS harness connector; it's located on the passenger's side of the engine just above the throttle assembly. Attach timing light to #1 plug wire. Start engine; the OEM timing should be 20 degrees BTDC on a DOHC and 15 on a SOHC. Loosen bolts and turn the distributor slowly while watching the timing marks on the pulley with the timing light. Stop the engine. Reconnect the TPS harness connector.
Also, there's an article on this at http://www.240sxTech.com.
