qsiguy »
https://forums.nicoclub.com/qsiguy-u27015.html
Sat May 24, 2008 2:22 pm
Geez no help huh, well I got it on my own. Hub puller pushed out the half shaft and then had to use a slide hammer to get the hub separated from the bearing sleeve (or whatever it's called). Once I got it out I realized there was another large bolt that I think is holding it in there. Not sure you could get the new wheel studs installed without separating the bearing section from the hub but I'm not sure. Repacked the bearings and it went back together pretty easily. Next time that will be much easier but dang that was a pain. Pretty stupid that you have to pull that hub off like that just to install new wheel studs.
