I spent about thirty minutes and two hundred curse words twisting and contorting under my dash trying to pop that thing in with my hands to no avail. Then I took the rubber stopper/grommet and pinched the sides with a pair of needle nose pliers and it slide right into place...took 10 seconds.hopesfallhxc wrote:How do you replace the rubber grommet behind the brakelight switch?? Mine deteriated and i made a makeshift one with tape and the old rubber stuff i could find. I believe you can get a whole new rubber piece at the dealer for a couple dollars, but how do you put it on. I can barely get my hands to reach back there. Any other suggestions on how to fix this? Thanks-shaun
I tried the needle nose pliers technique to no avail but I did figure out a no-brainer way to do it without much issue. It takes about 10 mins but is so simple it's ridiculous...If you loosen the brake master cylinder from the brake booster, you'll be able to push the brake pedal all the way to the floor without having to bleed the brakes afterwards. Pull the two nuts holding the master cylinder onto the booster and grab a friend because you will need an extra hand for the next step. Now, lay the driver's seat back all the way down so the seat is almost completely flat. Lay down on the seat with your face looking up under the steering column. Have your friend push the brake pedal all the way down with a piece of wood or other reach-extending device. Once the pedal is all the way down, you'll be able to just push the replacement stopper into the hole on the pedal assembly with your thumb and index finger. It really just pops right in! Head back under the hood and retighten those nuts on the master cylinder and you should be good to go!positron1 wrote:I spent about thirty minutes and two hundred curse words twisting and contorting under my dash trying to pop that thing in with my hands to no avail. Then I took the rubber stopper/grommet and pinched the sides with a pair of needle nose pliers and it slide right into place...took 10 seconds.hopesfallhxc wrote:How do you replace the rubber grommet behind the brakelight switch?? Mine deteriated and i made a makeshift one with tape and the old rubber stuff i could find. I believe you can get a whole new rubber piece at the dealer for a couple dollars, but how do you put it on. I can barely get my hands to reach back there. Any other suggestions on how to fix this? Thanks-shaun
Found this thread before I installed the part, and the above worked for me. I got the grommet somewhat seated over the hole, released the pedal to hold it in place, then pulled the pedal toward me to pop it in. Saved me some time and precious curse-words.marcus johnson wrote:Then I just pushed down the pedal and slid the pin in until I could feel the grommet seated properly in the hole. Released the pedal and pulled back on it to seat the plug... popped right in. Took maybe thirty seconds.
It's designed to fail with the lights on so you know something's wrong. If the switch worked opposite, then you'd never know your lights are out and would be running around town with no brake lights. The only reason Nissan opted to use the plastic piece instead of direct metal contact was to save the switch from an early demise since it wouldn't be slamming into the metal arm all the time.mechanicalmoron wrote:A better question would be, have they shot the guy who designed it so a broken grommet freezes your brake light on? Couldn't the switch have been LARGER than the mounting hole, so it would still engauge?
Courtesy parts time.
(edit) anyone know the difference between these? Judging from the chunks I found, mine was the black one, but what's the difference? Is each side (switch and pedal) supposed to have a rubber piece?
Ahh I would, but it would be several hundred miles round trip for a five dollar part, I think I'll just opt for another 20 years on one of the rubber ones from courtesy parts.Hijacker wrote:It's designed to fail with the lights on so you know something's wrong. If the switch worked opposite, then you'd never know your lights are out and would be running around town with no brake lights. The only reason Nissan opted to use the plastic piece instead of direct metal contact was to save the switch from an early demise since it wouldn't be slamming into the metal arm all the time.mechanicalmoron wrote:A better question would be, have they shot the guy who designed it so a broken grommet freezes your brake light on? Couldn't the switch have been LARGER than the mounting hole, so it would still engauge?
The plastic stopper has been updated, so if you go to your dealership, they'll have the updated part, which will be clear. It's a bit tougher than the old black plastic and should last the life of the car. And only the pedal lever arm will have the stopper.
This works just as well with a 99 Toyota Corolla. Many thanks to the author of this post. Spent about 40 minutes trying to force the brake pedal switch cushion - in Toyota-speak - into place in the cramped confines of the brake pedal/footrest area, before giving up for the day. Went looking on Google for a solution.tony2012 wrote:To put it in, you need to start your car, unfold your driver's seat all the way back and get your head under the dashboard. It's easier for you to press on the brake pedal when the car's engine is on. If the engine is off, it's harder to press on the brake pedal.
Use one hand to press on the brake pedal and the other to slide the rubber stopper into the narrow space between your brake light switch and the the hole on the pedal assembly. Make sure the nip of the stopper is facing the hole on the pedal assembly. There's no need to try to press the nip into the hole because the rubber stopper is going to slip off your fingers. Just hold the stopper in place with one hand and slowly release the brake with the other. The nip of the stopper will just snap right in to the hole!
