Yes if I remembered correctly only one side pop out. The side that's further away from the windshield (the side that you press on) comes out and the whole piece swing down towards the windshield. I am pretty sure this is in the owner's manual too. Check there if you have any problems.lybrian1 wrote:so do i just pop out the white/translucent plastic cover on the light?
The cover itself doesn't, but the plastics part around the cover does. I put a small indentation there when I try to pry the cover off using a very small flat-head. That's how I decided to use something flat and wide to twist it outst_donjuan wrote:I used plastic trim remove tool.Just slide it in there and twist it gently.That cover doesn't get damaged easily.
mike
