No. Regular threads on the axle shaft. I wouldn't suggest cutting it off because that's what holds the axle in the bearing.goody94q45 wrote:Are there reverse threads on that axle?
slo_coupe wrote:how about tryin a half-inch air gun with a proper socket? Axle nuts are usually torqued to almost 200ft-lbs than u have the rust that builds up on threads. An airgun will most likely do it for you.
