how do you remove the shift knob ? it's tight!!!
Ren
Car: 1995 240sx
I tried my bear hand.. then with a cloth wrapping it then use a plyer .. didn't work either..
Pleaes give me some help... if i force it too hard.. will it damage my shifter?
SeVa-S13
Car: '05 GTO 6spd
Vise Grips are often the only way. Sometimes those things are like chemically bonded, it gets nuts.
[Zero-S]
Car: Tell me whats wrong with this picture. 3 240's, only one runs.
They're locktited from the factory. Either spend ALOT of time twisting it off (worked for me) and keep it nice looking, or take a pair of vise-grips to is as the wise master said.
Again, I just toughed it out and twisted it. Alot.
Ren
Car: 1995 240sx
the shift knob is on now isn't the stock one.. the pre owner chagned it to a aftermarket one. and it's ugly..
will it be any damge to the shifter if i twist it too hard?
The Mic
Car: 3Z Wmb
i dont think so. just remember, Lefty Loosie, Righty Tightie
574-240sx
Car: Nissans, Toyotas, Subaru
Have you tried channel locks or a pipe wrench. If it has been cross threaded you are going to have a hard time.
Wraith
Car: 1993 240sx coupe
Might sound funny but I used a jar opener on mine, the one that has the thick rubber band, channel locks just kept slipping. Came off with one turn of the jar opener. Wife is the one that mentioned trying it, go figure they are always right
nsrZ32
Car: 90 Nissan 300ZX TT
78 Datsun 280Z
71 Datsun 521 Pickup
98 Nissan Sentra 2.0 SE
02 Nissan Altima 3.5 SE
01 Ford Focus S2
Gotta work out those forearms more often man. lol
Really tho, don't worry, you won't hurt the shifter itself (and if you do its all the more reason to get a short throw) just use vice grips and go nuts.
Ren
Car: 1995 240sx
damn .. I tried tried.. nice grips.. whatever tool available... still could get it off. what the hell was the pre owner done to the shift knob..
IlIkEmYz
Car: 06 Z
try lifting more weights and using a rubber coated glove... if that doesn't work use a monkey wrench.
MinisterofDOOM
Car: 1962 Corvair Monza
1961 Corvair Lakewood
1974 Unimog 404
1997 Pathfinder XE
2005 Lincoln LS8
Former:
1995 Q45t
1993 Maxima GXE
1995 Ranger XL 2.3
1984 Coupe DeVille
Use a knife. Or a saw. Maybe a plasma torch. Cut the damn thing off.
OR
You could always just buy a short throw shifter and put your original knob on that. Two birds, one stone. Of course, you may not be able to afford that...
getnrowdy23
Car: '95 sr20det 240sx se/2004 suzuki sv650s
try searching... it has been discussed before. i had to you a washcloth, huge byscripts, and a friend. had friend hold the shifter under the knob so i didnt break anything, and just turned as hard as i could. pop and she was loose.
andrave
Car: 1989 Nissan 240SX Coupe
yeah thats what I did, two big vice grips, two rubber mats for friction. brother held the one one the shifter, I held one on the shift knob, and I just yanked it. It was indeed covered in locktite once we got it off. I should also mentioned that this stripped the (pimp) leather cover off my factory shift knob, and left grooves in it from the vice grips.
MinisterofDOOM
1974 Unimog 404
1997 Pathfinder XE
2005 Lincoln LS8
Former:
1995 Q45t
1993 Maxima GXE
1995 Ranger XL 2.3
1984 Coupe DeVille
Wait...you used the vice grips on the factory shift knob? I thought you had one that was ugly, and needed to get THAT one off to replace it with the stock one...
Either way, you should have used a plasma torch
240marcuSX
Car: E34 525i
E46 M3
bro, just crack your nuckles get a tight grip. and grunt and turn at the same time. mind over matter.
Ren
Car: 1995 240sx
I finally got it off.. and changed to the CF nismo one.. I think the pre owner is crazy.. he installed one of those weird kind, I had to un screw the ring was on the base of the knob clock wise. then there are 3 more screws. and i couldn't get them because i didn't have the key for them. I had to take my car to the shop and have them to un screw them for me.. and they charged me. whatever.. got the the knob off. and discovered that the shifter was cut short. jus for that little ugly knob.
MinisterofDOOM
1974 Unimog 404
1997 Pathfinder XE
2005 Lincoln LS8
Former:
1995 Q45t
1993 Maxima GXE
1995 Ranger XL 2.3
1984 Coupe DeVille
Wait...they "key" should have just been a hex key. Maybe a Torx. Either way, you could have picked up a whole set for under $5. The shop ripped you off, man.
Ren
Car: 1995 240sx
yup.. Ive been a stupid ***. I just keep thinking it another.. just for a lesson.. makes me feel a lil better. SIGH
