fueler »
https://forums.nicoclub.com/fueler-u54519.html
Sun Jul 27, 2008 9:03 pm
well if yours is anything like mine, it has 2 taller racks and 3 small cross bars... they are all held into a slider on each side of the car... the racks have large plastic bolts on them so you can slide them forwards and backwards, just unscrew those plastic bolts (and on the 2 larger racks, its more like a large plastic wheel)
ur right about the bolts... they r 10mm bolts that you are undoing i went to home depot and bought small 10mm bolts to put in its place, like just to prevent the bolt holes from ever corroding or getting mud in them, just as good measure
PS pathfinders are different, this is for 97-99.5 qx4's
on the pathfinder belonging to slickroger, the roof rack is slightly harder to remove - i believe it involves unbolting the endcap of the rail and sliding the rails off the end
