Sentientbydesign wrote:That's because they aren't struts. Struts hold the spring AND provide dampening.
A shock or strut that holds a spring is actually referred to as coilover. The term has actually evolved as adjustable rideheigt coilovers became more popular, but coilover technically refers to any shock that holds the spring on its body.
That said, struts aren't struts because they hold the spring. Struts differ from shocks because they are a structural part of the suspension. Unlike a coilover shock, a strut bears quite a bit of lateral load. As a result, their bodies are much stronger. Since they bear lateral load, they also make up part of the suspension geometry. That's why strut based suspensions can gain camber/caster adjustments by replacing the top bearing with camber/caster plates. By changing the angle of the strut, you change the angle of the wheel.
The front shock spring assembly on the 350Z is a coilover. But it is not a strut as it isn't a structural part of the suspension. Its merely a shock that has the spring perched upon it.
