How do you remove the RB25 crank pulley bolt
exodus5547097
What do you guys do to remove the RB25 crank pulley bolt?
300Plus
Car: 1995 S14 w/ Rb25det Series II
don't use your teeth... TRUST ME
cdorhout
Car: RB30DET with VCT -- SOLD!!!!
Next project TBD
Righty tighty, lefty loosey.
If the crankshaft is turning have a friend put a breaker bar on the flywheel bolts to hold the crank in place.
exodus5547097
Thanks guys!
Darius
Car: RB25DET S14 - 665 WHP (SOLD)
Use this tool. Works almost every time.
silviasgp06
Car: 95 Nissan Zenki RB25 Powered
impact wrench works to remove it but use a torque wrench and a friend for putting it back on.
exodus5547097
well how do you use the harmonic balancer puller on RB25?
nizmo zilvia
Car: 95 240sx w/ S14 SR20 Blacktop
You use that. If you don't have a air compressor I suggest you invest in one. I bought mine for $50 from Lowes (8 gallon)
As far as the harmonic balancer, you're suppose to use a special tool for that.
See?
exodus5547097
what is the smallest size for that bolt in that picture?
nizmo zilvia
I have no clue. The remover I used was designed differently. Mine grabs the pulley from the back and when you turn the bolt right it pulls the harmonic balancer to you causing it to come off.
exodus5547097
nizmo zilvia wrote:I have no clue. The remover I used was designed differently. Mine grabs the pulley from the back and when you turn the bolt right it pulls the harmonic balancer to you causing it to come off.
can you appoint on what tool you got that from?
nizmo zilvia
Don't know where I got it from but I found it in my garage and it works great. Here is what it looks like:
Carl H
dont take it off if you dont have a torque wrench to put it back on.
