how do you remove the front spindle??????
nicc_dett
Car: S13_240sx_92_SE
ive unbolted EVERYTHING that the spindle is connected too! i need to replace my old one but i cant get the old one off. i'll go upload pictures maybe someone on here can help
Modified by nicc_dett at 1:14 PM 12/28/2008
Modified by nicc_dett at 1:21 PM 12/28/2008
OutToWinPAHC
Car: 2015 Chevy Silverado
Nissan Skyline R33 GTS-t
Nissan Skyline R32 GTR
Nissan RB20 E46 RHD
2015 Harley Vrod Muscle
1990 Nissan Patrol
The are pushed in tight. PB blaster and a rubber mallet. If that doesn't work apply heat to the spindle around the bolt then smack it.
OutToWinPAHC
Nissan RB20 E46 RHD
1990 Nissan Patrol
oh and dont smack the bolts with a metal hammer, you can damage the treads then you will need new LBJs or control arms and even outer tie rods.
sbird1
Car: 2006 BMW 325i
OutToWinPAHC wrote:The are pushed in tight. PB blaster and a rubber mallet. If that doesn't work apply heat to the spindle around the bolt then smack it.
Just beat the hell out of it. It'll come out without damaging anything. Just don't smack the bolt threads. You'll mushroom the ends and make it a big PITA for yourself.
EDIT: ^^^ Damn, you beat me to it.
nicc_dett
are you guys suggesting i hit the bolts with a rubber mallet?and heat up the bolts?
LOVERboy
Car: 1997 240sx se KAT
sbird1
Car: 2006 BMW 325i
Do NOT hit the bolts directly. Hit the suspension arms that the bolts are attached to and force them out. They will come out, they just take massaging.
Justin35ll
Car: s13 coupe sr20det
Hammer ftw, but like others said don't hit the bolts or you could damage the threads
hai1206vn
Car: 95 s14 se
yea, thread the securing nuts over those bolts and smack the nuts ... ouch
le_ryan
Car: Mazda3
91 Nissan 240SX SR
hai1206vn wrote:yea, thread the securing nuts over those bolts and smack the nuts ... ouch
put about 3 turns on it too, I actually broke my threads cause i didnt bring the nut down enough.
coupe240sxguy
Car: '89 240sx/ '01 mazda 626
to remove the part just use/rent a tie rod remover tool and a ball joint remover tool from Autozone. They will just pop off!
SirSilvia
Car: Sold both my babies
yup and maybe a pulley/gear puller same principle maybe?I wouldn't buy a tool I'm only going to use once.
94_240sx
Car: 94_240SX
This will make your life much easier. I think I paid about $25 at Autozone. Make sure to get adjustable like mine, so you can use it for all different types of ball joints.
coupe240sxguy
You can also rent that at autozone^^ http://www.autozone.com/in_our...l.htm no problem
sbird1
Car: 2006 BMW 325i
I still have Auto Zone's ball joint remover that I rented like a year and half ago... I should go return it and get my $10 back....
coupe240sxguy
sbird1 wrote:I still have Auto Zone's ball joint remover that I rented like a year and half ago... I should go return it and get my $10 back....
It is a long shot but you still may be able to return it, butwhen u rent a tool from autozone you have 90 days untill u own it. But that doesn't mean u still cant get ur money. I work thier and that is how I know all of this. Just talk to a manager and tell them that u were under the impression that blah, blah, blah, cause you were told other wise by an employee that works their no worries
Bumnah
Car: 1992 240SX, black. Bone stock.
i normally put the nut back on the ball joint and make it flush. i solid hit with a hammer and then one solid hit on the side of the spindle. easily pops off.
thefro526
Car: BMW 325Ci & S13 Coupe
I just threaded a nut on like a twist or two and then smacked it with a hammer.
I totally wish I had an adjustable puller thing like the one posted... Would've been sooo much easier.
nicc_dett
got everything finished last night, yay!soo i look around my car and 1 of my studs on my rear was GONE and 1 stud is stripped i decided to say screw the studs and drive it anyways with 2 lugs holding the wheel... its sooo bumpy and then 1 stud snaps, gotta do all of this allll over again best new years ever
SR24DET
Car: RMS13
I used the Tie rod fork from autozone. I payed $10 for it and have used it 100 times. Use it here and it will come out.
nicc_dett
^^yes, i used that too. and i highly recommend it to everyone.
mrzabala
Car: 93 Nissan 240SX SE Hatch
Well you guys are just lame. Whole purpose for us 240 owners, is cheap, easy to work on, can have sex with the seat fully reclined back, etc.
Stop being a ***** and thread the nut back on about 5 threads in. Than just give it some man hits with a hammer and it will come off. As for the spindle, it will be easier if you have it bolted up to the strut because the arm will just keep bouncing from every hit.
Have fun and to your lame pullers
OutToWinPAHC
Nissan RB20 E46 RHD
1990 Nissan Patrol
You really made a DIY for rear seat removal?
vancouverbc
Car: 1991 240sx
helped me but the pics are dead.
vancouverbc
Car: 1991 240sx
[QUOTE=vancouverbc]
i bought this for around $15. have not tried it.
