how do you remove back speakers?
General discussion area for the L32-chassis Altima
pntofnoreturn
Car: 07 nissan altima 3.5 se
anyone know?
Atomic-S14
Car: 2009 Altima 2.5S
I just replaced my rear speakers today.... but now I can't put the rear deck cover and the rear upper side pillars back on... almost messed up my rear tint trying to force it back in.
so my question is, how does the rear deck cover go back in? do I put the back side first or the front?it feels like the deck cover it not seated all the way towards the back and the side pillars are having a hard time lining up with the holes and the clips.please anyone that has changed the rear speakers help me.
Atomic-S14
pntofnoreturn wrote:anyone know?
So in order to take the speakers out, you need to remove couple of things. Go to this PDF file and look at page 38. < http://www.nicoclub.com/FSM/Altima/2009/INL.pdf > It will tell you how it comes off.But take notes as you take yours off, so you can put it back together and not end up like me... LOL..... But the rear pillars comes off first and you take that off by taking off the caps and undoing a bolt, then gently undo two clips (one by where your door is and another one around the middle somewhere) and pull it off.
Modified by Atomic-S14 at 3:26 AM 7/2/2009
pntofnoreturn
yaa i finally figured it out and it all has to do with lining it up perfectly. But be very careful because those clips are so brittle. I broke 2 trying to put it back on lol
AllenEW
Car: 2007 Altima
Went to this site and it appears page 38 is gone, I did find two links to Removeal and installation instructions but they don't work, anybody help ??
The links were INT-11 and INT-15
I'll keep looking but a little help would be apreceated..tia
Al
pntofnoreturn
You have to first remove the 2 side panels that are for the airbags. There's two clips which you can pop off with a screwdriver which exposes the bolts that you have to remove. After removing the bolt, just pull on it and the clips will come off. Then the whole back piece is done with clips so just pull it up and it will come off. When putting back together, put the big black piece first (starting with the back and moving to the front) and then they 2 airbag covers.
AllenEW
Car: 2007 Altima
Thanks, got the front door speakers figured out, it was the rear deck that was confusing me, once again..thanks.
Al
AllenEW
Car: 2007 Altima
Al
Sorry for double post.
Modified by AllenEW at 6:57 PM 9/26/2009
Return to “4th Generation Altima Sedan (2007-2012)”
