how do you remove active suspension?
My President is Black
Car: 1993 Infiniti Q45
im not sure if theres already a post about this i searched and couldnt find anything but i was wondering what is involved in removing active suspension i decided thats what i want to go with so any info is greatly appreciated. thanks.
maxnix
Car: 1995 Infiniti Q45
1995 Infiniti Q45t
2000 Infiniti Q45
You can loop the PS pump, but you will have a heavier pump than you need.
Other than that, you remove all active components (extensive and not easy) and replace where necessary with regular components.
There are a lot of differences, tension rods, main pulley, dash display,.....much easier to buy a nonactive than to downgrade an active and not end up with a heavier than necessary car hauling around useless dead weight.
qship96
Car: 1996 Infiniti Q45
Scottsdale Infiniti{www.everythinginfiniti.com} sells a kit with everything needed- look on their site under "specialty kits" in the Q45 section
Will cure all current and future expensive headaches caused by the old overcomplicated semi-active suspension system in a few hours time
goody90q45
Car: 1992 Infiniti Q45 (sold)
Jerod did a great job of documenting his active to base conversion:
zerothread?id=255581
Do i need to spend the time and money removing all this stuff though. Couldn't i just put in coil overs and not use the active. When i took off my wheel there's nothing really in the way, so it seems easy enough to do. The only downside being some extra dead weight but wouldn't it be feasible to do so?
Infinitiguy19
Car: 1993 Infiniti Q45 188580 Miles
1994 Infiniti Q45a 240000 Miles
No you don't have to remove it. But if you do you will gain MPG's and some power. After all you will lose .2 seconds off the Quarter mile.
But why remove it does it currently work now?
Because some people actually do get lucky in life and they might not have to downgrade the suspension (Q45Tech would call it good maintenance on the Previous owners part).
Panther in a Q45a
Car: 1995 Q45, 1994 Q45, 1974 Pantera, 2006 Hummer
You need to start by replacing the shocks and springs to units made for a non-active car.
zer...rings
Modified by Panther in a Q45a at 3:48 PM 6/23/2009
silver2k2
Car: 1994 Q45 Ivory Quartz/Tan
Let me know if you have any specific questions, you can post them in the other thread so we can build that thread to be more comprehensive
