How do you remap the CA18Dett chip for a Z32 AFM?
pulsar gtr
Car: NISSAN VEHICLES
HI,
I bought 300 ics of the 27c256 a while back and I never used them, if any one is interested in buying some let me know, I will give you a better deal than any one else.
Thanks,
Rafic
biosehnsucht
I was too braindead to remember what to call it at the time, you want a SPDT switch, and connect the address pin to COM and +5V to A and GND to B (or swap A and B, doesn't matter).
There's various sorts of SPDTs, probably even some push-button instead of toggle-switch ones, but as long as it is SPDT it'll work.
Actually best would be SPDT along with some other crap to anti-bounce the change but this will work.
datsunboy
Car: Datsuns
uh.....is a SPDT just a normal toggle switch?if not...whats the difference?
biosehnsucht
well you can have a switch that is SPST which is the same as above, but no B terminalso for example you either feed it +5V or nothing (disconnected)hopefully the EPROM would have internal pulldowns to make a floating input on the address line fall to ground, which would work fine then, but no telling...you can get SPDT's in many flavors (push botton, toggle switch like the bottom of the pic, DIP switches, sliding switches..)
your typical on/off switch is a SPST switch .
slw240sx
Car: 1990 Ca18det 240sx Hatch
i believe im using the 256 chip, i spent 40$ on chips that didnt except the programs.... and they made me wait 2monthes for nothing.. . . instead the chips i got for 50cent a peice work
go figure
biosehnsucht
the chips that didn't work, what are they? if they're UV-erasable types are you sure they were erased before hand?
datsunboy
Car: Datsuns
so the correct switch is just anyone that works in the way of your diagram?I have more of those sort of switches lying around than 2 pin ones!......lol
biosehnsucht
haha yes, as long as it operates like that doesn't matter how it looks, other than how you want it to look.
nab911
Car: 93 Nissan 240SX SE
Sorry to rehash an old thread but slw240sx, if yo ustill have those .bin files can you email me them at [email protected]Thanks!
Vetal
Guys, has anyone had problem with changing EPROM?I've tried to modify fuel maps and set speedlimiter to some 70mph just to check and there's no difference... Car runs like before... limiter doesn't work also... What am I doing wrong?
