Hi!
tpuig wrote:Z, just come by the DreamLot Garage. It's in Mountain View, right off 101 and 85 at Shoreline. Should cost only a couple bucks (about $20 or so) to put your new ride up on the lift there. Give you a good chance to check things out as well. Call Ben, 650-964-4699 and schedule an hour or two. He's there from noon until 10pm. I only live about 3 minutes from there, and would love to lend a hand if you like. TP
p.s. I still need to put the shocks on the '94Q there as well.
I called Ben a couple of times last year and got a voice recording, so I left a message but did not hear back from him. I did not try him this time 'cause I did not see this post till just now, but I will give him a call again next time.
If I had had a lift or a ramp, I could have done it easily myself, but not otherwise. It is pretty much impossible to reach the filter from above on an M45 - too many things in the way. From below, it is easy once the flap in the engine shield is unscrewed, but because of the shield itself, it is not possible to look at where to reach, etc., without being underneath the car!
I just had the oil and filter changed about an hour ago at an independent garage just down the street from where I work. I brought the filter ($7) from the Infiniti dealer, 6 quarts of Castrol GTX 10W-40 ($11) and they charged me $15.99 (for a total cost to me of $33.99.) I got to oversee the work, and I am satisfied it was done right, and the price was good enough for now.
In the future, I think ramps will work for me! My garage is flat, but the driveway beyond is sloped just right, so I think a ramp on the driveway will keep the car level enough for it to drain okay, and the rear will not hit the ground, since the ramp slope will be on the driveway. Since I plan to do frequent oil changes, this may be worth it!
Thanks for all the comments, folks!
Z
