How do you pull the blower motor out from undern the dash?
ob1
Car: 95 240sx S14
I want to clean the blades on the motor doses any one know how to pull this unit out of an s14 dash?
ob1
Car: 95 240sx S14
Has anyone done this with the dash in the car?
positron1
Car: Project: 1993 Nissan 240SX Coupe SR
Daily: 2010 Honda Civic Coupe
If it's like a S13 then the blower motor is behind your glovebox.
ob1
Car: 95 240sx S14
Thanks man I know where the motor is but am unable to pull it out. I have unscrewed every bolt but cannot remove. What did you do to remove yours?
Bongpain
Car: 92 240sx
there should be like 3 bolts and a flat head screw driver and twist it should drop. nothing else is should be holding it on but the insulator foam.
ob1
Car: 95 240sx S14
Thanks I will try tonight to get it out . I will unscrew the screws I see and pull on it thanks for your response.
ob1
Car: 95 240sx S14
I tried to pull the motor out after a while i removed the ecu and was able to get to the last screw. thanks again
