Postby
Milky6 »
https://forums.nicoclub.com/milky6-u21387.htmlWed Mar 16, 2005 3:53 am
How do you lower your clutch pedal to make the distance to disengage shorter? I own a 90 fastback and i need to push the clutch down way farther than my friend's fb. I just want to know if you can adjust it as well as the brake pedals. Please help... thanks.
Postby
sensibleS13driver »
https://forums.nicoclub.com/sensibles13driver-u19985.htmlWed Mar 16, 2005 8:01 am
If the brake pedal has too much travel then you probably need to bleed the brakes which will lessen the travel and make the pedal more solid and more responsive brakes.
