naed240sx »
https://forums.nicoclub.com/naed240sx-u28231.html
Mon Jan 02, 2006 4:28 pm
My 225/50/16 tires on a +35 rim will not clear kts in the front. Rears have plenty of clearance.
You will not need spacers in the rear, But I would suggest using a 10 mm spacer to make them more flush. You will want the 50 mm studs if you use such a spacer.
For the front, You will want a maximum offset of +30, which might still rub slightly depending on what tires you using. I would suggest using a 10mm spacer up front as well, with the extended 50mm studs.
Studs are easy to swap out, I just recently did mine in the front.
