would the 2005 be a rev up?C-Kwik wrote:The rev-up motor uses a different intake plenum. It also has variable cam timing on the exhaust cams where the non-rev-up version only has it on the intake cams. The rev-up version revs to 7000 RPM and likely has slightly beefier rods to handle the additional tensile load of the higher RPM.
Also don't forget.04G356MT wrote:Infiniti = NissanLexus = ToyotaAcura = Honda
The badge makes no difference on class. If you want to brag about having a Infiniti go ahead but you still have a luxury coupe nissan.
GM makes alot of cars , From Cadillac To Saturnjoe603 wrote:Gotta add a few:
Ford = LincolnGM = Cadillac
I like my Infiniti badges...but that's just me.
so if a non rev up motor were to face off with a rev up motor.... stock for stock, how badly would the non rev up get beaten?C-Kwik wrote:The rev-up motor uses a different intake plenum. It also has variable cam timing on the exhaust cams where the non-rev-up version only has it on the intake cams. The rev-up version revs to 7000 RPM and likely has slightly beefier rods to handle the additional tensile load of the higher RPM.
BINGO! You're prize will be mailed to you shortly. It's a JDM catalog!!! It's written in Japanese, so you won't be able to read it or order from it, but if you put it on your dash board, it's good for an additional 8 HP !!!!pits200 wrote:
Of course I know that Nissan=Infiniti, I am just curious why someone would rebadge their this way. Maybe its the whole japanese concept,but do as you will, its their car.
