marshun wrote:i believe mine is out too. i want to know how to jump this if its possible
i know this post is old, but i was searching
Once again this post has grown old, but in case you never got your answer:
Look closely at the bottom side of the relay (the side with the pins) and you will see a number next to each pin. Now look at the top side of the relay and the diagram will show you what each pin does. The two pins with a coil drawn between them are what operate the coil - so leave them alone. The remaining pins are what the relay operates - what you must jumper. I won't go into detail on how to read schematics, but if you'll google for help with reading relay diagrams you should be able to successfully bypass any relay. For example, on the simplest of relays there will only be a pair of pins remaining. They will show a line between them but not quite touching one. This means the connection is normally open, so you want to close it - put a jumper between these pins.
