How do you jack up the A/C
All things Altima Coupe.
migs7585
Car: 08 Altima Coupe 2.5s Super Black
where r we supposed to jack the a/c?
Blackmobile
Car: 2008 Altima Coupe 2.5S Super Black
under the car!
read the manual, it's got the jack points. jack it up on the frame of the car where there are 2 knotches. there's a pic in the useful book in the glove compartment
natalia3689
Car: 2009 Nissan Altima Coupe 2.5s White
its in the manual. there are two like knicks in the frame of the car.
migs7585
im looking and i do not find lolol im an idot
SHIFT_COUPE
Car: 2014 Infiniti Q50 AWD
Please try to make you're thread titles a little more descriptive. You'll receive a quicker response.
Look in the index in your manual, its there!
migs7585
sorry.....i got peoples thank you lol
PHENOMenalVinyl
Car: 08 altima coupe 2.5 mt
migs7585 wrote:im looking and i do not find lolol im an idot
depend on the Jack are u using a hydro or stock one .... Stock lay ur azz down n look 4 the notches ....... Hydro same or use the transmission
Ricko
migs7585 wrote:im an idot
Lol, its kool man. That is what we are here for!
migs7585
ya i used a hydro so i wasnt sure....found the lil notch thingys for the reg jack so i kinda put the hydro in the same spot...worked out fine...thats guys...first time i has to jack it so i was a lil confused
Rmuth25
Car: 08 Altima Coupe 2.5s CVT [Premium & Tech Packages]
When I do it I use the scissor jack in the stock location and raise the vehicle then I put jack stands right behind the front wheels little in. There is part of the frame(at least I hope its the frame) that is silver and is just the perfect width for the jack stands I have.
I used to use one of those normal floor jacks but it bent the little tabs where the stock scissors jack is supposed to go and I figured I didnt want to bend them much because if I got a flat and had to use the scissors jack on the road I would be screwed if it did not fit.
Viper5000
Car: 2009 Altima Coupe 3.5SE/6MT
yeah guys, the factory location with the tabs on the frame is only for the stock floor jack, using any other kind of jack will bend it fo sho....
rjdmmfl1
Car: 2008 Altima Coupe, Radiant Silver, 3.5SE, Premium Package, VDC
$50 jack from kragen http://shop.oreillyauto.com/Pr...=3397
, autozone http://www.autozone.com/autozo...ber=1
works perfectly on our cars, even on lowered ones....
mrodrig2
Car: 2008 Altima Coupe 2.5S CVT
You can use a floor at those spots with the appropriate rubber or plastic adapters. Some brand name jacks come with the adapters otherwise I think they are around $10??
jdeb101
Car: 2008 Altima Coupe 3.5SE
Im kinda embarrassed to ask this...but I've been wondering where to place my floor jack so I can change my oil. Is the transmission really a safe spot? Thats the last thing I want to F*** up. I was thinking more somewhere on the body frame is better??
TIA
yoonzilla
be sure to always use jack stands people! the jack shouldnt be the primary support.
jdeb101
jdeb101 wrote:Im kinda embarrassed to ask this...but I've been wondering where to place my floor jack so I can change my oil. Is the transmission really a safe spot? Thats the last thing I want to F*** up. I was thinking more somewhere on the body frame is better??
TIA
Anyone???
