MECPInstaller »
https://forums.nicoclub.com/mecpinstaller-u9687.html
Thu Sep 09, 2004 11:46 pm
I'm pretty sure if you look under your steering collum you will find your main ignition harness, a bundle of wires that are thicker than the rest under the dash (usually like 10awg or so) . Locate your +12volts wire then touch it to the one of the ignition wires in the harness. I'm not exactly postive on it but just trying to recall from what i know when i installed alarm systems. I'd first try playing with yoru broken tumbler, pulling it out and see if theres anyway you can rotate it .
Find a service manual for you car and make sure you locate and identify the correct wires.
One thing you might run into a problem with is if the steering wheel lock still works, car will run but won't be able to turn with the steering lock still working. I know some how theives can shatter the lock but i myself don't know how they go about doing it.
A word of warning, if you car has airbags, steer clear of wires wrapped in yellow tape, or in a yellow sheath or loom. People can be killed by airbags.
I had a audio/security instructor who's buddy had died, because he used a test light and tested the wrong wire while his was down near the seat and steering wheel. Long story short airbag deploys, snaps his neck and kills him.
