1njen wrote:This is for all the 6mts.
Okay, so let's say a left turn is coming up and you start to break from 40mph. You don't need to come to a complete stop. Sooooooo do you...
B) Down shift, engine-break a little, make the turn all without touching the break.
Wouldn't break ware be better than engine/clutch ware? It IS significantly cheaper.
I rarely use my brakes unless I have to.
For example lets say I'm doing 60 & in 6th gear and a left turn is coming up.I will downship to 5th,then to 4th, then to 3rd, & then to 2nd gear & make the turn in 2nd gear as it brakes the car to around 20 MPH while in the turn. After the turn accelerate as conditions permit.
Exiting the New Jersey Turnpike or any high speed freeway, slow down from 75 MPH or so to 60, downshift to 5th on the off ramp to 45 or 50, downshift to 4th or possibly 3rd to 30 MPG go thru toll booth with EZ Pass & accelerate after toll booth never touching the brakes unless there is a A$$hole in front of me.
Downshifting will not wear out a clutch. Brakes usually last me over 100k miles and clutches close to 200k miles
Highly reving an engine & poping the clutch to burn rubber will.
Telcoman
