How do you get the to the (TCU/TCM) Transmission Control Module in an 02 Q45/F50
bdf
Car: 2002 Q45 Premium, sold
2011 M56S
I know where it is, behind the glove box behid a panel, but I cannot get that panel off. I took all of the screws out and it still woudl not budge.
Then I need to source an upgraded TCM of course. Will any TCM from an 03-06 Q or from an 03-04 M work? I am doing the TSB for acceleration my self.
maxnix
Car: 1995 Infiniti Q45
1995 Infiniti Q45t
2000 Infiniti Q45
The TCM is upgraded only through an ITB for the early models.
The TSB has been posted before, so you might check to see if your VIN is in the addressed sequence.
bdf
2011 M56S
Yeah it is in that group, already had the ECU flashed, but they cannot flash the TCM, I have to replcae it, they want 900 to do it. If I can find one ill replace it my self. I even know where it is. i just cannot get to it.
maxnix
1995 Infiniti Q45t
2000 Infiniti Q45
Why sould they not reflash it? I thought is was a part of the TSB?Which dealer? Sewell?
bdf
2011 M56S
Well, the older first generation TCU in teh early Q cannot be flashed. Crest infiniti if it matters
Now, does anyone know how to gt that panel behind the glove box off?
Q45man1
Car: 2002 Q45, 1994 Q45
When mine was done before the warranty expired. ECU flash and TCM was replaced. It cannot be flash, but need to be replaced.
bdf
2011 M56S
I appreciate you guys attention, but irrelevant questions and restatement of things I already know are not going to help me.
One last time:
DOES ANYONE KNOW HOW TO ACCESS THE TCM, I CANNOT GET THE PANEL BEHIND THE GLOVE BOX OUT TO GET TO IT, IT MUST BE REPLCED.
If you can tell me that or where to get the newer TCM or which models M45 Q etc, that is fine otherwise, please use the search function or at least read the entire thread before you post.
maxnix
1995 Infiniti Q45t
2000 Infiniti Q45
Q45man1 wrote:When mine was done before the warranty expired. ECU flash and TCM was replaced. It cannot be flash, but need to be replaced.
Ah, but with what? All the later F50 had the 3.13 differential.
bdf
2011 M56S
See now that is actually helpful, Mine being an Early 02, what TCM will work, or will they all? Will the M45 03/04 work, what ration did they have? what ration does mine have? Does that matter to the TCM?
maxnix
1995 Infiniti Q45t
2000 Infiniti Q45
If Nissan replaced the whole TCU with the bulletin, then that would be a specific unit for the 2002 as it was the only one to have the 2.93(?) final drive.
Shifts points would be affected. Maybe TCS also. REgardless, it is programmed with the expected final ratio, which would throw off the speed calculations.
Q45tech
Speed is derived from ABS sensors unlike 4AT where there was an actual on transmission speed sensor.
Newer version of 5AT have TCU integrated in AT housing to minimize external wiring.
