Tulsa_S-13 »
https://forums.nicoclub.com/tulsa-s-13-u29811.html
Sat Sep 17, 2005 11:10 am
First off, you definately don't need a rebuild. When I first bought my car, the exact same freeze plug leaked as a result of being rusted.
First drain your coolant out of your engine.Then remove your exhaust manifold and anyhting else in the way.After that, you can simply take a socket and using a hammer hit it out of the hole (do not hit it dead on, but at an angle).After that take yoru new freeze plug (which you can get at your local Nissan dealership, and make sure its metal) and put permatex sealant around the edge of the plug, then using a socket and hammer, hammer it into the hole. Put everything back together, refill coolant, bleed coolant, and VIOLA, no more leaking antifreeze.
I've driven my car for 7 months after replacing the freeze plug and I haven't had any problems at all.
