How do you enable navigation while the car is moving?
Hari
Many times I want to look up an address while my wife is driving. How can I enable navi while the car is in motion? Thanks a bunch! It will only be used when I'm the passenger. It's so annoying when you are trying to find something to have to pull over.
Sentientbydesign
Car: 03 Evo VIII - 330 AWHP
05 Subaru Legacy GT Stg 2 - Sold
05 G35 6MT Coupe - 278 WHP - Sold
04 WW Evo VIII - 302 AWHP - Ex's
96 I30 - Sold
Welcome to NICO!
Here you go:
zerothread/331450
Do get into an accident and then blame it on us lol.
joe603
Car: 2014 Durango R/T
Welcome to NICO!
Check out the G-series FAQ (link in my sig) for tons of info on your car!
Hari
Actually, now that I read it through that one mention DVD only and says that Navi requires the speed sensor wire to be toggled on. Is there another method?
EZcheese15
Car: 2012 Juke SV
2011 Titan Pro-4X
2007 BMW 328i
Hari wrote:Actually, now that I read it through that one mention DVD only and says that Navi requires the speed sensor wire to be toggled on. Is there another method?
Unfortunatly for safety reasons, you can not "switch" it without some hacking of the wiring. It's not a difficult procedure, but it does require you to take apart the dash and cut a couple wires. This is also illegal, but I'm sure you'll be using this for "off-road purposes only."
Hari
Ah ok. It's not worth the trouble then. Good thing I have a good sense of direction.
Sentientbydesign
96 I30 - Sold
You could probably find a way to rewire the thing to be independent of the speed sensor, but that would require quite a bit of work.
EZcheese15
Car: 2012 Juke SV
2011 Titan Pro-4X
2007 BMW 328i
Hari wrote:Ah ok. It's not worth the trouble then. Good thing I have a good sense of direction.
Well you're in Marietta too, and I've done this on my G, so if you ever need some help with it, just let me know. I don't have nav, but the same mod is required to play video while driving.
C-Kwik
Wiring in a toggle to cut the signal wire when you want to program the nav is the simplest way to do this. Its actually somewhat necessary as the nav will not adjust your location while the speed signal wire is cut. How difficult it is to do might vary with which vehicle you have (Not sure which G you own).
zozoka1212
Car: 08 Infiniti G35x
Hari
Check your email.
zozo
