How do you do a compression check???
Former_240_s14
Car: 07 BMW 335i Coupe
Hey guys, I have searched but couldn't really find anything, so here is my question. How do you perform a compression check???
Thanks,Rubin
p.s. reason why i am doing this is to just make sure motor is ready for f/i.
mattback
Car: being a big f'ng ricer
1: remove spark plugs2: un plug distributor3: screw in compression tester gauge4: hold throttle wide open5: hahaha forget you didnt unplug injectors7: unplug fuel injectors and remember you forgot step 68: get in car, hold throttle wide open, crank for 10 seconds9: take reading, and record.10: repeat for other cylinders.
slw240sx
Car: 1990 Ca18det 240sx Hatch
just pull the fuel pump fuse instead of the injectors themselves.. at least i would think thats a easier way to avoid the fueling and do them a few differant times on the same cylinders to make sure you get a accurate reading ! i still havent done my CA im scared to see what the compression is across all 4 cylinders !!
DAEDALUS
Car: 1990 Infiniti Q45
Or pull the injector fuse. If you only pull the pump fuse you'll have gas spraying into the cylinders from the residual fuel pressure in the system. Not a big deal either way, but the mist could wash away oil from the rings, possibly affecting the reading (very slightly).
Calvin
Former_240_s14 wrote:Hey guys, I have searched but couldn't really find anything,
http://www.240sx.org/faq/index.htmlunder "compression test"
Former_240_s14
Ahhh! there it is...thankyou my friend! : )
Former_240_s14
Well I actually did find that one, but the s13 had different distributor setup so I wanted opinions on how too, thanks though all of you regardless!
