How do you check your fuel pressure?
newdude1
K so Im trying to figure out a few things before I send my ecu back off to jwt and one thing I wanted to check was the fuel pressure. Because its suppose to be at 43.5 and my electronic gauge is saying 38 psi. I think I heard you can tap a T unit in the vac line from the fpr. Is this correct? Im using a Vacuum gauge to check it.
bruinbear714
newdude1 wrote:K so Im trying to figure out a few things before I send my ecu back off to jwt and one thing I wanted to check was the fuel pressure. Because its suppose to be at 43.5 and my electronic gauge is saying 38 psi. I think I heard you can tap a T unit in the vac line from the fpr. Is this correct? Im using a Vacuum gauge to check it.
IIRC, its around 43-44psi at WOT and 38ish at idle assuming you have a stock FPR.
newdude1
Well I just called jwt and they told me at idle its tuned for 43.5 and my car is extremely lean at idle. and I know it doesn't go above 40 on my gauge at wot. But can I check the pressure by tapping into the vacuum line to the fpr?
Justin35ll
Car: s13 coupe sr20det
No you'll only get a boost/vacuum reading there.
USMCgetsome
Car: OWN S13.5 RB25DET/2003 G35
hey new dude you might have to interest yourself in a digital fuel pressure gauge that you can put in the cabin
