After removing the screws wiggle it back, it's held in there by little clips.BryanWSD wrote:I've searched and can't find an answer. How do you remove the brake light? I took out the 2 screws, but couldn't quite get it to come out easily, and I didn't want to break some plastic part inside the light assembly.
Anyone know how to safely remove the assembly so you can change the bulb?
Thanks!
Good deal! If you start a new thread with a step-by (even if it's only a few steps) we can link it in our new "How To" sticky if the mods ever get it up. When dealing with any kind of resistance with clips it is a little freaky. I know I've broken my share of things because I thought they were held in by clips.BryanWSD wrote:Ok, that was embarrassingly simple. Can't believe I had to ask the question. Once I had the confidence to just pull and that it wouldn't break, I had both lights done in under 2 minutes.
I'll try to post a pic later so others don't have to suffer the embarrassment I just went through!
You know there's a section under 'pathfinder/qx4 faqs' that has links to most of the how-to's.. I dunno if that was pre-bit**ing or post. Although I think it would be a good idea to still have a 'how-to' sticky all by itself.Empty V wrote:
Good deal! If you start a new thread with a step-by (even if it's only a few steps) we can link it in our new "How To" sticky if the mods ever get it up. Billy
