How do you change oil pan gasket?
1980-1986 Datsun 720 forums. All 720-specific topics and discussion can be found here.
j1rm
Car: 94 Accord auto. 90 Z32 (in the works)
I looked down there and looks pretty complicated! Is there a way to do it that doesnt involve lifting the engine?
breadbox
Car: 89 Nissan 240SX
89 Koop
84 720 4x4KC
Sometimes it does involve jacking up the motor. Depends on the motor.
I haven't done it, but I have a 4x4 so I have a front diff in my way. on 2WD it is much easier.
breadbox
89 Koop
84 720 4x4KC
1. drain oil
2. Start unbolting oil pan
3. if you have an impossible to get to bolt, then jack up the motor and get it off, and try to remove pan. Inspect oil pickup and replace as needed.
4. put new rtv and bolt it back to spec.
5. then finish the oil change.
breadbox
89 Koop
84 720 4x4KC
Also guessing from the sig, you have a S13 hatch, most likely a 240sx.
Does everyone with an S13, buy a nissan truck as a second vehicle?
j1rm
I no longer have the 240. I traded it for an 85 corolla... then traded that for my 85 720. couldnt be happyer. needs many chanes but still kicks and runs
j1rm
theres this piece that goes from one side of the chassis to the other thats right infront of the oil pan. you know how it goes slim then bulky towards the back? well its right in front of the bulky area and then the transmission is right behind that area. It looks like a cross member
breadbox
89 Koop
84 720 4x4KC
lol, I'd have to be reading that while staring in my motor bay to know what you are talking about. But spanning to either side of the truck does sound like a front subframe cross member, I could be more helpful with a picture circling what you are talking about.
The part of the oil pan that drops down the lowest is called the sump, Trucks are usually rear sump meaning the cross member goes in front of it.
j1rm
i dont have a camera. My phone takes gay pics and its too low to get under it to take a pic
breadbox
89 Koop
84 720 4x4KC
Why go to an AE86 after a 240? Usually its the other way.
I guess it doesn't matter now that you wised up and Got another Nissan.
breadbox
89 Koop
84 720 4x4KC
Also you should enable your PMs. They are handy for quick responses.
PEZi
2wd model...
remove sway bar
remove suspension crossmember
lower steering crossmember by unbolting it from the mounting point on the passenger side frame and knocking it down (may need big rubber hammer)
that will make the pan able to drop out and clean and replace gasket
j1rm
i just wanted something different. Had no job and everything was leaking in the 240. No one wanted to buy it so i traded it a few months later. then after having the corolla for a month i just had to go back to Nissan. Toyota seems like a female brand. Everything inside of it seems girly.... idk maybe just me. Now that i have the 720 it just seems RIGHT! I also had a white 91 300zx twin turbo. 240 was white and 720 is white
j1rm
it looked like i had to remove that cross member but i didnt want to have to go through all that, but now that its confirmed i must.transmission is leaking too. the oil pan is WET like a horny school girl!
PEZi
yeah the process is annoying. they made it where there was just stuff in the way lol. the pan drops without lowering the steering crossmember but you can't get the pan out of the truck without lowering it because the oil pickup is in the way of removing it
flinterman2000
Car: 2000 Nissan Wingroad, 85 Datsun 720 Pick Up.
Its easier to drop out the oil pick up than to drop the steering cross member. Its only two bolts to remove but you have to be careful not to damage the gasket and when reinstalling the pick up pipe.
PEZi
it wasn't on mine... there was no way i could have reached the pick up easily enough to remove it either way... i know on mine the steering crossmember took about 30 seconds to drop and 2 minutes to reinstall
flinterman2000
Sometimes its like that. I dropped the steering cross member this time when I was redoing the mountings and repairing the sump, because I did not have the right size of socket wrench.
BattyUSA
Car: 85 740 King
Awwwww Cmon guys. Quit Ur whining. :cry: U act as if it is such a big deal. Try it on a 4x4. I have 1 w/ a bad #4 rod bearing. It sat 4yrs B4 I got the bloody engine out. 20min later after the steam bath the bearing problem was confirmed...and I didn't have 2 struggle w/ the oil pan or damage the pick-up. And just think...when all is said and done, mine will have all new parts and no leaks...and run better than URs. :rotfl Oh well. Good luck 2 U...and 2 me. :wavey:
PEZi
ummm... welcome? congratulations?
j1rm
hahaha! f.ing guy! Hey batty im glad you can do all that work and be so full of pride as to post it on a forum that doesnt belong to you!
Rev_D21
1991 D21 Reg 2WD Auto
1995 D21 Reg 2WD 5Spd
1996 D21 Reg 4WD 5Spd
2012 Versa 1.6S 5-Speed
On my KA all I did was drop the engine crossmember to get to the pan. I forget how different the Z series pan is to from the KA though. I used a big punch to line the bolt holes on the x-member when I was done.
Return to “Datsun 720”
