newdude1 wrote:So do I set the fuel pressure to 43 with the vac line disconnect and when I connect it, it should be at 38?
Yes, roughly.
newdude1 wrote:K now I got the lines right and I have fuel pressure. But its leaking at the threads on the fpr. I used teflon tape. Was I suppose to use something else?
Yeah I dunno, you must have done something wrong. I don't think there is any tape on mine at all.
So fuel comes up from the bottom-right. It goes to the filter. The filter then has a hose that connects to the middle-right side of the fuel rail. From there, it goes out the left hand side (near the firewall) via the NISMO fpr adaptor. After that, it goes to your regulator, and from your regulator it goes to the return line back to the tank.
I suppose you could really put the gauge wherever you want, as anything in front of the FPR will have the same pressure. Just make sure you don't put it on the return line after the FPR.
