how do u clean (IACV)??????
Flip240sx
Car: 1992 nissan 240sx SE
anybody? what kind of product should i use for this????and the right way to do it.
S13FASTBACKSR
Car: '92 Fastback SR powered
its really not very hard at all..to clean it just take the idle adjustment screw all the way out and spray carb cleaner into the hole..then if you have an air compressor stick the nozzle down there as far as you can and hit it with that..also what you can do is take a piece of wood and put it up against the iacv then hit the wood with a hammer to knock built up carbon loose...so basically hit it with carb cleaner, hit it with air (if youve got access to that) and then hit it with a hammer and piece of wood..i did this process starting with a full bottle of carb cleaner and ended up with barely any left...incase you were wondering how much to use.
vancouverbc
Car: 1991 240sx
This thread covers this topic with pics.
zerothread?id=124542
